Water Pump Kit #, or Impeller #...
frustratedboater
Gentleman,
I am looking for an impeller for my BF-15A, 96' Honda 15hp. Serial: BAAU1000135. I'd appreciate any kit numbers or impeller replacement numbers if you have them. Thanks again...
~FB~
frustratedboater
That is perfect and thanks for the info. I kinda was thinking on just replacing just the impeller and gaskets because the housing is in such good shape and the plate not really worn. Thanks for the help...
tommarvin
Ensign
I would tear the water pump apart first, does the Sierra impeller, and gaskets match yours ,if so this will be the least expensive impeller and gaskets.
I know it sounds backwards but, you have to replace your impeller just before your first launch of every season. See if the Sierra impeller fits first.
Our Sierra impeller costs 13 bucks at iboats.com, I have seen the same impeller cost 30bucks or more.
If you need help on the install just ask, were here to help you through it.
Sea Rider
Will depend entirely on the impeller brand and the material it's made from, there are brands and brands, if hardened after one year change it, if not could use it longer. Tohatsu impellers outlasts any other impeller brand by far...
Happy Boating
hondam
Honda has 2 kits:
1 they call a service kit, its an impeller and required gaskets. BF9.9A/BF15A - 06192-ZV4-000
2 the rebuild kit, includes everything in service kit plus housing, wear plate, and hardware 06193-ZV4-000
