I have a 2003 Ski Centurion with a Mercruiser 350 MPI towsport engine, 315hp, v-drive, inboard. The last two weekends I've used the boat the first day it runs fine and on day 2, when I start the engine the drive belt won't turn after the engine is running and it makes a screeching sound, I assume from the belt trying to turn, as if something is frozen up in it and preventing it from turning. The first time this happened I let it sit for a few hours and then tried it again and it ran perfectly. I purchased the boat used and don't know if the impeller has ever been replaced although the boat only has 85 hours on it. I was told by a mechanic that impellers can sometimes get reversed. Any thoughts?
