Jhilton0816
- Apr 10, 2015
- 78
i removed the impellar housing to check to see if i needed to replace the impellar, it was good, i guess the place that winterized it for me changed the impellar, i also changed my tstat and cleaned up the housing a bit, and found a bunch of big impellar fins probably from a previous impellar. i cleaned up the old gasket put a new gasket on and replaced t stat and put the housing back in place and connected hoses, i start the engine and however now it over heats.... i pull the hoses and it looks like no water was being moved. i unook the top hose that goes to the t stat housing and started the engine and sure enough no water was coming out of output of the impellar housing.... so i take it off and turn the impellar around incase.... no change, i then took it back off again to see if the little sprocket that goes through the impellar moves when engine is running... sure enough its moving. i then put the impellar and housing back the way it was and put it back on the water pump... i then started the engine and wanted to make sure the impellar was moving so i put a flad had lightly in the top output port and sure enough the impellar fins were hitting the flat head due to it moving.... my issue now is why isnt any water coming out???? mind you all the hoses were emptied prior cause i pulled them off to replace the thermostat..... so they are all still pretty much dry.... but i need help... do i really need to replace the water pump? if i do which part do i need exactly, and how much is it? i only run the boat in lakes if that helps
