LOSTINEVINRUDE
- May 29, 2006
- 28
HELP IN THE MIDDLE OF REPLACING WATER PUMP 1990 70hp evinrude need to no wher o ring goes on drive shaft . no o ring on shaft when removed. Kit states o ring must be placed on shaft
lost,
the oring goes on the top of the drive shaft where it connects to the power head. If you did not have the oring there before I would crack the heads and see if the is any water damage inside the cylinders. That little oring is what keeps water from entering the combustion portion of your motor.
Basher
