kippstakes
- Jun 10, 2013
- 117
Took the motor into the shop yesterday with a starting problem. Called me back today claiming the engine started right up and idled fine, however once it heated up water quit flowing from the indicator hole and the engine became very hot very fast. This was puzzling to me since I installed an entire pump kit no more than five minutes of run time ago, so it seems almost impossible that I need a replacement impeller. My guess is that something is wonky with the thermostat or the pressure valves.
What do you think?
What do you think?
