mercurymark
- May 31, 2003
- 21
I have a 1975 7.5. At idle, I get a little water shooting out the tell tale hole and what appears to be some exhaust gas. When I rev it up a little, I get a good stream of water. It seems to me that somewhere the exhaust is overpowering the water pressure and that is causing the spurts I'm getting at idle. Then, when the speed is increased, the water pressure overcomes the exhaust and you get a steady stream. The question I have is where could the exhaust be getting to the cooling water? I changed the impeller last year and it does the same thing with a new impeller.
Any help would be appreciated.
