ole miss gal
- Dec 28, 2005
- 17
Hi all.<br />I was helping a friend of mine change his waterpump (outdrive) of his boat (95 Alpha +).<br />I suggested he purchase the complete kit but he opted for a rebuild kit. Anyway, he has it pretty much back together (still has not attached the upper to the lower) because there seems to be a slight problem. We installed the impeller/gaskets etc, but the little rubber "slinger" I guess is what it's called (fit's over the shaft and slides down onto the top of the pump). It doesn't seem to fit right for some reason, at least to me it doesn't. it doesn't seem to slide all the ay down and fit into the top of the pump as it should.<br />I changed mine a few weeks ago and I don't recall this being an issue. Exactly what is this rubbers purpose (besides keeping water from escaping and causing major bux)? Is this all it does, just curious about this one.
