Northernbob
- Dec 6, 2009
- 27
I just put a rebuilt engine (4.3)in my boat (240hrs since new) . New manifolds to. Engine runs fine etc. Everything went back together well, no extra parts, I took lots of pictures so everything is back where it is supposed to be. Timing is good. Oil pressure is good. No fluid leaks.
It overheats at idle, It will cool down at high idle 1800rpm, with thermostat out. So I have no idea what the PO did to this boat as far as maintenance.
I want to change the pump impeller. Raw water cooled. Can I remove the lower gearcase (alpha1 genII) without removing the drive from the boat?? Do I need to drain the gearlube first??
Thanks
Bob
I tried a search but can't go advanced so way to much reading.
Thanks
Bob
