hotrod53
- Oct 16, 2009
- 508
I disassembled my water pump and obviously the impeller needs to be replaced. I was looking at the impeller cup and it has some slight groves in it, does that mean it needs to be replaced or is that normal.
I would assume that the impeller, water tube O ring, the thick ring on the top where the shaft comes in, impeller plate, and the gaskets on each side should be replaced, what about anything in the water pump base? I guess there are O rings in the bottom somewwhere too??
