Water pump repair
LindenLongRods
I have an 1987 Johnson 88 SPL. I'm doing my water pump no problem so far, but by trim tab there are 2 bolts one kinda small (part66) and a bigger (part63) I doesn't say anything about removeing these on the link provided from earlier post, but that engine is a 1985 the guy is working on. do I or don't I have to remove these additional bolts? I already removed the trim tab bolt and the one underneath and also 3 bolts holding lowerer unit. the last one is just hand tighten so it doesn't fall off.I broke the seal(Paint) it definetly seems 1 bolt is still holding. Any help? yes I unhooked gear linkage!!!!
Dhadley
Re: Water pump repair
Should be 4 bolts (2 on each side), one under the tab and 1 larger one just ahead of the tab.
LindenLongRods
That's the one . It's stuck fast I tried PB Blaster and heat and an impact wrench no luck!! corners of bolt are stripped. don't know what to do!!! any suggestions???
Daviet
Sometimes you can grind/cut the bolt head off and work the lower unit off of it, that will leave the shaft of the bolt to work with.
boobie
Get a metric socket and drive it on to the head of the bolt. Then heat the area around it with either a mapp gas or a acy/ox torch. Work the bolt back and forth when heating.
boobie
Glad to hear you got it but what did you do ??
