water pump replacement mariner 135 hp-1997
sullymate
I have the repair manual and have read it. one question, does the shift rod have to be disconnected or will the shift rod just slide out when all bolts are removed and the lower unit is dropped? or is there a bolt that holds the shift rod in place underneath the powerhead? Also it is a cam-shift model so should it be placed in forward gear before work is started? Also i want to install a water pressure gauge, the directions say to locate the plug in the water cooling jacket. I see a brass plug on the water jacket with an "F" shaped plastic part with 2 hollow male ar coming out of the plug. obviously the plugs are not open or being used. Is this the connection for the water pressure gauge? thanks for any info you can give me. Sullymate
KCLOST
Re: water pump replacement mariner 135 hp-1997
The shift shaft will disconnect right above where the lower unit connects to the drive shaft housing. The upper shift shaft will not fall out but it can be pushed upward when you reattach the lower unit. You need to be careful to line up the splines on the lower shaft into the upper or you could push it up and never get them attached. I like to use a shim of some kind to place above the shift linkage where the upper shaft attaches. This helps to keep it from moving upward and makes the installation easier IMO.<br /><br />I think the plug where the pressure guage fitting will go is at the top of the block right behind the outer edge of the flywheel. It's a plug that measures 3/4 or 19mm in diameter (actually 1/2" pipe thread). I'm getting ready to install one on my motor.<br />I'm not really following your description of the "f" shaped plastic thing. <br /><br />My installation is to remove the plug (mine has no plastic piece), install a 1/2" male to 1/8" female brass bushing reducer, install an elbow into the bushing and attach the hose to the elbow.<br />Here is a good link to installation instructions on several motors.<br /> http://www.tflx.com/PDF/99376.pdf
JB
Moving to Merc/Mariner Troubles.
