water pump replacement
BFSGREG
is there anything I should be aware of when replacing water pump on 1987 15 hp evinrude outboard
watched some tech tips on youtube but I have never done it myself
example how to uncouple shifting linkage etc........
thanks
AlTn
Re: water pump replacement
shift to forward, remove 6 screws attaching gearcase to exhaust housing < gearcase ( lower unit ) should drop down ~1">, remove lower screw from the brass coupler, lower unit with driveshaft should now slip out...google Leeroy's Ranblings and find his writings on the 9.9/15 hp. models it'll all be covered there as well as pics
