Re: water pump replacement
There's not much tricky about the job, but the first time you do it, it'll take you a bit longer considering the "learning curve"....I did mine in about 2 hours, but I deliberately took my good time in my feeble attempt Not to screw it up!
....it went off without a hitch!....Check/clean/ replace your thermostat and pressure control valve while you're at it...then you'll know your cooling system is in good shape!....good luck!
