water pump
gotsaved
could someone tell me about what the cost of having a new impeller installed in a 125hp force 1988.
OBJ
Re: water pump
Hi ya' got....<br /><br />What do ya' need to know? Don't know what the price would be on your particular impeller but I have seen impellers for larger engines priced around $30+ dollars.<br /><br />Labor varies from shop to shop. I would suppose anywhere from 45 to 55 dollars per hour? I'm just going from my area on this.<br /><br />Bout' all I can tell ya' ecept if you need the impeller changed out because of overheat problems, you ain't got much choice unless you do the job yerself.
Jerry M.
Re: water pump
Recently had the impeller and pump housing replacd on my 50 Merc for $240. Labor was $118 of that total. It included replacing the seals and greasing the prop shaft. Took about 1 1/2 hours of labor. It was part of the deal when I bought the boat. <br /><br />Before I committed to replace the impeller, have you checked the thermostat? Something you can easily replace yourself. If you have a thermal tester you can check the temp on either side of themostat to see if it's opening.<br /><br />Jerry
roscoe
Re: water pump
$37+/- for the impeller, $3 for a gasket, 2 hours labor. You can do it yourself if you have a manual and some basic tools (wrenches).
