water pump
ambdriver
i have a bayliner cuddie capri with a 85 horse force, going to put a water pump in it myself, anybody have problems? anybody have any tips or hints?
Re: water pump
Check the "Sticky" thread at the top of the forum. I just changed mine on my '87 85HP and it was very easy using the directions that Frank had noted.... Good luck...
HMC49
Re: water pump
I would recomend having someone there to help you put the lower end back in.
hawkf250
Re: water pump
When you are putting everything back together, be sure to grease every boyt well with thick axle grease, this will help prevent corrotion that seizes bolts
hawkf250
Re: water pump
Also, if there are blades missing from the old impeller, be sure to check the water tube for restrictions, cant count the number of times that I pulled a water pump with missing blades and found the jammed up in the water tube that goes to the engine
