Water pump
73Steury
Can someone tell me what direction the water pump turns. I removed the impeller last fall and now that it's going back together I can"t remember what direction the impeller turns. The manual doesn't show it.
Thanks
Wingedwheel
Re: Water pump
It doesn't matter which way the fins are installed. when the motor is started it will correct itself.
1960 Starflite
Re: Water pump
Yep ! A little grease on the impeller blades will help with engagement. Push down on the impeller and turn the shaft at the same time.
