Boilers2000
- Jun 15, 2018
- 252
Manual says to add perfect seal to small hole gasket. Both sides, side with the face plate or side that contact lower unit?
Thanks in advance
Thanks in advance
Do'h my bad, alpha one Gen 2 from 92. I watched the video on YouTube that was linked in the adults only section ( video was by Chrisa660, is that you? Great videos, super helpful!). In that video they just put the small hole gasket, face plate and large hole gasket on and that's it.What ya workin' on?
No idea if you're talking about a Bravo, an Alpha or an engine...
Chris...
'Tis... Guilty as charge your Honour.... video was by Chrisa660, is that you? ...
Those holes are blind, but should be clean before you put the screws back in. I use compressed air. I then coat the screws with AquaShield so they'll come out again in 3 years... Can't remember if those are blind holes or drilled through right now.
Your videos are awesome and super helpful. Thanks a million for sharing your knowledge'Tis... Guilty as charge your Honour.
Chris......
