Water saturated decking and freezing temps
r_marczak_83
During the last couple days we have had 6+ inches of rain that pulled my cover down to create a catch all in the middle of my boat. This started to drip through the cover and saturate the decking. I always leave my drain out when not in use, so its been draining. However in the last day temps have reached a high of 26 F. Its froze solid around the drain hole. Is the freezing bad on the boat decking?
rallyart
Re: Water saturated decking and freezing temps
The water will not normally get into the decking, other than carpet. If it can get in to the decking the decking is already wrecked so not a worry. Just make sure it can dry when it warms so mould does not become a problem.
