water separator on Mercruiser 4.3
tonyjh63
Hi, been having some starting issues, even after having the plugs, cap, and rotor changed, AND after been running a while. A boat mechanic tells me on the phone it may be the fuel/water separator getting clogged up...
Can anyone tell me exactly where this part is on my motor, and how hard it would be to change? My motor's serial number is: 0D850955 (My outdrive serial number is: 0F033851 if that helps any).
Thanks for any help!
Don S
Re: water separator on Mercruiser 4.3
You have a 92 model and it didn't have a water separating fuel filter that year. Only an inline filter (item 12 below).
In 93 an newer, they used a water separating fuel filter, after seeing the error in their ways.
They do have a kit with steel line, fittings, brackets etc. to replace the original.
Here is one on ebay.
http://www.ebay.com/itm/35-807172A-...ILTER-KIT-FOR-V-6-4-3-LITRE-NEW-/200821026217
tonyjh63
Don S, thanks so much for the reply! My boat is a '93 Glastron SSV 195 Elite, so it kinda sucks that I still have a '92 motor.:-(
How hard would it be to retrofit that kit?
Thanks again!
Thanks again!
Ayuh,... Ya just mount the housin', 'n run the fuel lines,... Not hard at all...
Fixerup
Not to highjack but I just got my fuel water kit from NAPA, but on the back it says not for 92 4.3 alpha one gen 2. Can I just remove inline filter and install the kit? Thanks
tonyjh63
Ok, so the boat ran great a few times, but tried to crank it on the ear muffs (I always crank it at home and let it run for 10-15 minutes before towing it to the lake nowadays) last Thursday, and no go. I thought maybe I'd try replacing the fuel filter (not sure how well I would do trying to retrofit the fuel/water seperator kit), but can't find the part. Can anyone point me to a source for this part? Would one for automotive use work (i.e., Autozone)? Thanks!
tonyjh63
Update: Turned out to be the hose going to fuel pump!
jonny rotten
I have a 91 glastron.Just added a water separator.I screwed it to the side of the engine compartment.10 min job.Cut the rubber hose coming off the fuel pump.Go to Auto Zone buy a 2' 3/8 rubber fuel line and some hose clamps.Mount the separator,run lines and hose clamps...done
