Water Separator
jason176
I have ordered my new boat and am anxiously thinking on what I may need or want to do to it. I read a post that it is a good idea to install a water separator on the motor (60hp 4stroke efi bigfoot). My question is what is everybodys opinions on this and usually when I have seen a water separator they had bowls on then that were removeable or drainable to drain the water, I looked through the marine store and they have alot of them with just a canister filter, where does the separated water go?
rickdb1boat
Re: Water Separator
I think it's a good idea to have one. It's certainly not gonna harm anything. I had some issues a while back with a little water finding it's way into my fuel tank and that's when I installed one(The spin-on canister type). I did not run one for years prior to this problem, nor did I have any problems then. But I do feel better knowing that there is some measure of protection in using one if the need arises. The water being heavier than fuel, settles to the bottom of the filter and the good stuff keeps on flowing on by(That's the theory anyway)....On the Racors with the clear bowls, you can drain them every once in a while on the bottom...
JB
Re: Water Separator
A water seperating fuel filter is absolutely required on an EFI 4 stroke.
tashasdaddy
Re: Water Separator
jason, most i/o run the canister type.
Mark42
Re: Water Separator
Originally posted by jason176:<br /> ....I looked through the marine store and they have alot of them with just a canister filter, where does the separated water go?
Some is absorbed by the filter element, but I think most of it just sloshes around in the bottom. <br /><br />That's why I ordered a small Racor filter with clear removable water collection bowl. Also the filter is not supposed to let the water pass through. We'll see. Good for 25 gallon per hour, more than enough for your 60hp even if it is 75% plugged up and you're running WOT. Carry a spare filter cartridge to be safe. <br /><br />
dajohnson53
Re: Water Separator
First, I would never own a boat with built in tanks withou a water sep. filter. I would never own a boat with portable tanks - if I was going to use it off shore or in a remote place - without a water sep. filter. I guess I'm saying they are not only good to have, I believe they are basic, "DUH" equipment.<br /><br />I've used both and prefer the bowl/drainable type. The plain cannister type are often/generally used in an engine compartment (e.g. I/0) because you can't use a plastic bowl inside an engine compartment. They do make brass and steel bowl models however that can be used there. A lot of times the issue is clearance - you wouldn't be able to easily drain a bowl inside some compartments, or there would be risk of spilling fuel in the bilge.<br /><br />I'd say the type with clear bowls are more common on outboard applications.<br /><br />Those no-bowl type you just replace the cannister on a schedule. If you wait too long and the cannister fills up, you can get water to the carb or EFI.<br /><br />The reason I like the bowl type is that you can drain the bowl and monitor it. I do replace the cannister part of mine every spring anyway, even though I've been told it isn't necessary. With these type, you can have the same problem if you don't keep it drained - the whole bowl and then the cannister can fill up with enough water to cause you problems. BTDT - when I first got my current boat and was ignorant and unaware.
jason176
Re: Water Separator
I see what you are saying with using the cannister type when space is an issue. I just found it wierd that you would separate the water from the fuel and it will just sit in the cannister until it is replaced meanwhile filling up and possibly being drawn into the motor. I am gonna get one with the removable bowl when I get the boat. Anyways, thanks for all the replies.
jason176
Re: Water Separator
Mark42, Will that specific filter separate water too, I looked in the store and didn't see it in the details?
