Water separator.
ski_king
I've been having issues with my boat running bad and I'm pretty sure the issue is bad gas due to 10% ethanol in the gasoline. The motor is a 1989 125 HP Force OB. Any suggestions for a water separator and mounting location?
Mark42
Re: Water separator.
Racor seems to be the standard in water filtering fuel filters. Go to the racor site and check out the filters with the blue water bowl at the bottom. Lets you see and drain the collected water.
Regarding mounting, I think the best place to mount it is where it is easy to see and access. Proximity to the motor or tank is not important.
