Water Spray at the stern
redgin
I have a lot of water spray coming from the stern of the boat going about 20 mph or faster. The boat is 2155 Bayliner Sun Bridge with trim tabs and a swim platform but the swim platform isn't in the water. The spray comes from aft to mid ship. How can I cut this down?
Thanks Bob :/
tashasdaddy
Re: Water Spray at the stern
trim out properly, and try shifting the load. i assume it's an i/o and propped correctly.
Ayuh,........
Either That,.........
Or You're Dragging Something............
Capt said:
The spray comes from aft to mid ship. Thanks Bob :/
It Sounds like you need to Retract the Tabs,+ Trim the Drive......
Sounds like you're doing more Plowing than Planing.......
Reel Poor
Is the antiventalation/cavitation plate broken? Do you have a transducer mounted on the stern of the boat? Either of these can also cause spray.
redgin
Thanks for your input I will check Bob
