skiMachine
- Aug 9, 2004
- 10
Hopefully someone can help me out here... I'm new to boat ownership and maintenance (but learning oh so quickly). <br /><br />I've got a '84 Mercruiser 3.7L 170HP (I've heard some people call this a 470...I dunno) and I just started it for the first time this Spring. It started fine and I was going to let it warm up so I could drain and change the oil, but then I noticed a lot of water pouring out of the drain hole at stern. <br /><br />I peeked under the cover and saw a lot of water spraying from around the rear end cap of the heat exchanger, so I shut the motor down immediately. I've started it once or twice since then just momentarily to verify that is the place where it's leaking from. <br /><br />My question is what do I need to do to fix it? It looks like a nut on the end, which makes me think it's removable and individually replaceable. Is that possible, or do I need to replace the entire exchanger?<br /><br />For a bit of history, I got this boat before the winter last year and a friend told me that since it's a closed cooling system, I didn't need to do any draining. I've since bought a service manual and learned that there were two drain plugs on the exchanger that I should've opened. Could this have done the damage? <br /><br />...hoping to get the boat wet this month. Thanks in advance!
