Water tank fittings
Aviator04
Hey guys, could anyone tell me the correct way to install male threaded fittings into a water tank? Would I use thread tape, o-rings or anything else for that matter? I tried asking the guys at westmarine but no one had an answer for me. Thanks!
Ayuh,..... Is the fitting brass or plastic,..??
loctite 565 is what I would use
can use 3M 4000 UV here too.
airshot
I have had good success with tape on plastic fittings. Not sure I would use anything permanent, odds are, you will need to repair/ replace in the future
kcassells
Simple...Teflon tape and pipe dope. Just put the pipe dope on the edges of the insert thread after Teflon tape. Minimal amount needed. No rocket science needed here.
Monster tape is awesome, but any tape would work.
Run tape on the fitting to the right {clockwise} so as it is screwed in then the tape won't back off.
Thats all you need. Don't over wrench.
Make sure you have visual access or hatch for future work. Don't bury it.
