Water Temp Sender
Johnson110
Question, I am replacing the water temp sender on a 1995 5.7 mercruiser, what do you use foe sealer on the threads I am reading that teflon tape is a no-no, so what should I use? Do I have use any at all ?
Don S
Re: Water Temp Sender
Any pipe thread sealer (except tape) will work, if your new sender is an OEM part, it should have a redish brown sealer already on it.
Johnson110
The sender that I was going to purchase is sierra 18-5897 which is what the application calls for, the old sender is longer and fatter than the replacement, the threads are the same. Can the replacment part be different that the oem part ?
cr2k
NAPA parts are OEM parts.
Ayuh,... Are ya sure you got the Sender, 'n not the Switch,..??
Johnson110
Yes it is the sender for temp, it just has a much smaller end to it compared with the oem part that I took out!
