water temp
stormy123
whats the normal operating temp 0f an 84omc 3.0 just put in a new thermo stat n gaskets didnt have one in it im running bout 170 that sound bout right
Re: water temp
Ayuh,.... On the muffs, or in the pond,..??
Re: water temp
Are you reading the factory temp gauge (the lowest cost gauge on the dash), or are you using a tool such as an IR thermometer, ot thermo-couples?
If you have a 160 degree thermostat, and your gauge is off, you may be fine. I would rent an IR thermometer myself to know
stormy123
Re: water temp
just recieved a 6 gauge set of faria dress white gauges that i ordered mainly cause my tach was jumping around alot and a couple cracked lenses are these gauges reliable
Re: water temp
if your asking if Faria gauges are reliable, the answer is they are as reliable as any other brand. are they accurate - NO none of the gauges are accurate. they are accurateish.
another question. we assume you put in a new impeller when you did the thermostat, correct?
