While taking off lower unit to change water pump, the copper tube broke off about 2 inches inside the mid section portion of the lower unit.Question if I simply push the broken section into the mid section of the lower unit,what is the chance the water will travel mostly into the tube to the powerhead.Im not sure how tight the fit is with the pressure of the lower unit being bolted back on.
