water tube on 75hp Force
ferdly1
After replacing kingpin on engine bracket assmbly I am reinstalling the watertube and grommet. according to the parts breakdown they show the smaller end up. Is this correct. It doesnt fit into opening on upper plate and will end up being crushed. Seems to me it should be smaller end down. Any one familiar with this motor. I am including a diagram. Number 4 is the grommet 5 is the water tube and 1 is the adapter plate the water tube fits in.
GA_Boater
The diagram shows the flare is up, so the small end goes down into the water pump. How could it fit any other way?
ferdly1
Sorry about misunderstanding . I was referring to the grommet which is number 4. On the grommet it shows smaller end up which just gets crushed. Might be better if I took pictures.
tommarvin
Ensign
Looks like the smaller diameter end is up, looks like it goes up inside an opening.
What do you mean by that it would get crushed?,
jerryjerry05
Try sliding the grommet on the tube from the small end??
​Then push assy. up into the spacer plate.
ferdly1
Thanks guys, I figured it out. The diagram is wrong. Then again this is an old motor,
