Ryeandwater
- Jul 2, 2012
- 9
I have two bilge pumps, one is automatic, that can be turned on from a switch on the dash, or is activated by the "Water Witch" sensor. The other pump is manual only. Yesterday I noticed that the automatic bilge pump was running continually, turns out the float switch thing was stuck on. Tried whacking it with my trusty screwdriver, but no luck. Finally ended up cutting the wires to the switch. I was still able to turn it on from the dash. So the Water Witch sensor has three wires, but any other float switches I can find only have two? To replace the Water Witch is going to cost me about 100 bucks Canadian. How would I wire a new float that only has two wires? Or maybe I would be better to buy a new bilge pump with a built in float.
