Moody Blue
- May 24, 2004
- 3,136
Started out trying to find out why I was getting water in the LU. Dropped the LU and did a pressure test that showed a leak at the base of the waterpump.
So I took the pump apart and pried up the base. What I found shocked me. The wrong base was installed. The collar that fits down inside the housing over the bearing was at least 1/4" too small in diameter. Its P/N is 46-48747 (lower item in photo) The O-ring seal was doing nothing. I have a second complete LU (for parts), so I took that pump assy apart and found a different style waterpump base. Its P/N is 46-58618 (top item in photo) I tried fitting that base into the first LU and it was a TIGHT fit, almost size on size.
Now I have no idea what the proper waterpump base should be. The lower unit of interest has the helical cut gears, preload pin on the driveshaft and tapered roller bearing as the driveshaft bearing. The P/N of the LU casing is 1623-4021 and it has the flush port. See photo.
Anyone know what P/N base I should be looking for? There are SO many P/N's and I have no idea what year this LU actually is.
