Re: Waterpump Question
Thank you Mark
It was the first hole you mention I was referring to. You are correct in that it plugs up easily.One blast of compressed air fixed the problem. As for feeling the head for Temperature a big 10 4 on that because that was my thought as well.
It sure is nice though to have the added confidence from those who think alike and I thank for your help.
One more related Question: Is there any point or advantage to replace the pump impeller (if working) just as a routine maintenance or does it fall into the If it aint broke dont fix it category?
Everyone has their opinion and I am the don't fix............kind of guy. Just open yourself to problems that you may not have had before you started messing with things.
I bought my engine 2 years old in 2004. PO had replaced the impeller. I replaced it this year and it had a "set" in some of the blades even though I spin the engine every once in awhile since it sits for quite awhile between outings. Had no temp problems with it as it was and the tell tale at idle would shoot water a couple of inches below the surface....plenty of pressure.
I boat in clear water and it's fresh.
If you are a guy that spends a lot of time in sandy shallow water, highly polluted water with whatever, or you leave your engine sit up for 6 months or so (guess) you might consider every couple of years. Some guys profess every year. Well maybe that fits their boating style and gives them peace of mind.
I follow the axiom that it's your money, time, and equipment. Your choice.
Mark
