1991 Force 150 with Morse controls<br />OK, I am a newbie to boats but have had this one for about 3 months and am starting to get the hang of messing with the engine.<br />My only problem (knock on wood) is that I do not get much power in reverse, as with the control all the way down in reverse, I only get around 1500rpms, and in a current it is pretty scarey. forward WOT is perfect at 5200, and it idles good in neutral at 8 or 900. <br />My question is, can I adjust the linkage to the carb to increase the reverse max rpm without effecting everything else, and if so how? I have had advice that if I am happy with everything else then to learn to live with a weak reverse and don't touch anything.<br />From my Clymer's manual, I see how to adjust the linkage and cams on the carb, but am kinda nervous about doing this. Is there any other solution to this problem? And why would the range of rpms on everything else be right but be too low for reverse.<br />Or is this rpm about right for reverse and it is just a habit of Force motors?<br />Advice would be terrific!
