Weak spark at coil. No spark to plugs
Status
Not open for further replies.
Steverobbo79
Hi there i have a V8 5.0 92 model. Carby. Its just had the compressions tested before its sold. And now it wont start. I have a weak spark from the coil. I have done some testing and replaced rotor and the pick up inside the distributor. Caps nice and clean. Its a thunder bolt 1V with the module on the riser. Am i looking at replacing this module as i know these control the spark and advance. Has anyone had the same problems.
Thanks in advance
Steve
Ayuh,.... Welcome Aboard,..... I suggest ya do the entire diagnostic sequence stated in the factory manual to see what's wrong,.....
The factory manuals can be found in Don'S Adults Only section, found at the top of the I/O forums, or in my signature,....
Steverobbo79
Thanks Bondo i have already gone through the entire book and i have done all tests required. I cant find no info for testing the module. I have tested and replaced all the other parts.. only leaves the module. Its like the module is holding back on amplifying the spark.
Status
