Wear ring question 01 xlt 1200
cemiii
The rear bearings apparently washed out and failed (again). There are some sizeable grooves in the wear ring. I know I'm going to have to get the impeller serviced but how bad does the wear ring need to be before total replacement? Has anyone ever tried minor repairs with JB weld, or is this just foolish. I'm not that concerned about the last couple MPH just keeping it running for the kids.
Also, the starter relay seems to die every year even tucked away in a nice dry garage. It is a total PITA to remove the e-box to replace. Is there a common cause of this occuring that I should be checking out? using oem replacements.
Any thoughts appreciated.
Chris
