Weber Carb rebuild problems
ckgreenman
I've got a 1996 Mercruiser 350 Magnum with a Weber (aka Carter) 4 bbl carb.
I'm in the middle of disassembling it for a rebuild and have run into a problem.
While trying to remove one of the primary metering jets my screw driver slipped off and has screwed up the top to a point that I can get it out. I've found a source for a new metering jet but I have no clue how to get the bunged up one out of there.
Does anyone have any suggestions?
Thanks
tractoman
Re: Weber Carb rebuild problems
Those jets are soft. You could try a left handed drill bit. Hopefully it'll break loose.
Ayuh,... use a very small Easy-Out...
ckgreenman
Cool. I kinda had a feeling an extractor was what I need. Is there anything I should try to do to loosen it. That sucker is really tight.
ckgreenman
Ok New problem. Any suggestions on how to remove a broken easy-out from a stuck jet and then remove the stuck jet?
