have got myself a seahawk4 have made the floor the box seat with swivel chair ,taken the mod from someone on this site about the battery box being made out of a milk crate , the crate I will cut out the panels with a hot knife so my battery will fit in. mount the battery box\seat at the front of the boat have a plastic waste pipe that runs the length of the wooden floor to the 40lbs thrust motor where the wires are placed inside
can i use an inverter 12volt 240 volts from the battery would it drain power quickly from the battery if i put a charging unit on it would it work. or what about a solar panel for charging it (no much luck in Scotland
of sun what would you do ?????
also been noticing that if I put an old seagull outboard the intex motor mount seem to tilt when its in the water only observed this while watching you tube trying to get ideas for my boat is there any way to strengthen the transom so this does not happen
once I have my boat the way i want it will post photos , thanks bun ps have a seagull outboard and a 40lbs troll motor, any help would be nice , thanks bun.( Iain)
