Re: Weight distribution hitch anyone?
Thanks for all the interesting posts.
I am trying to figure out if you are describing the WDH as an Equilizer/anti sway hitch? (two bars come out of the hitch and attach themselfs to each side of the trailers frame?)
If it is a Equilizer/anti sway system, take the bars off before you launch if the drop is sudden 12% 14% 16% slope because thats alot of preasure you're applying to the truck/trailer and hitch.
Mine is the one with 2 L-shaped bars with chains on two sides & hooks to hook on to a V-tongue of a trailer. I bought this for my dump trailer. Never used it. No stabilizers.
I don't understand the whole WD hitch thing. It seams some people want to use one for the sake of using one, some people want to use one because they don't want to upgrade the truck and other people use them because they think they have to. I tow a 10K boat and trailer with a class 5 hitch just fine.
I'd like to use a WD for a couple of reasons: one is my hitch reciver only rates at max (12.5k on a F250) when used with a WD; 2nd is to keep the whole rig balance (no sagging points at rear) which in turn helps breaking & reduce swaying. With my current setup, I did tow my dump trailer to about 12-14k before and it's pretty scary. Hahaha. If the guys put too much weight on the back of the trailer (unbalanced load), it'd sway too even on a lighter load (at >52-55 mph).
I take it you have never used one hence the comments.
Curious what you think updating a truck would do unless you are talking about overhauling the rear suspension.
I have a feeling you don't understand the benefits of a WDH. Transfers some of the tongue weight to the front of the truck. Towing my boat makes a huge difference in stability.
Yep!
Most of the time, it isn't the hitch that is the problem. (and many hitches are coming built in now, part of the frame...) My current SUV is like that, and yes, the towing capacity is higher with a WD setup.
Beefing up the rear suspension in any way is NOT the same as a weight distribution hitch. WD hitches can load down the front of the vehicle, there is no way changing the rear suspension can do that, simple physics say that if you push down on a single point behind the axle, the front end is going to get lighter. Through 2 points of contact, a WD hitch can lift the back and push down on the front.
Yep! That's why even if I switch hitch receiver, since I already have a WD setup, I'd like to use it too if it's not tooooo much work involved for the big advantages it provides, at least on a heavy load (like a 2002 280) on long trip.
The factory installed hitch receiver on a new F-350 is big, rated for more than 17k lbs for WD, but only 8k lbs conventional. I mean, I would can still tow it (as mentioned, I did 12-13k with my F250 with my regular receiver, which rated only 5-6k lbs conventional).
I was of course didn't know how much weight it was, run really slow & cautious, only short trip (30 miles or less), and all the safety stuffs.
So yeah, back to the WD again:
- can those with a WD for their BOAT post some pictures please? Thanks
Nhi
