scott hamilton
- May 28, 2002
- 215
I have a Aluminum 18 ft Sylvan Skipper from 1979 in excellent garage kept condition that I am redoing. I have a 79 Evinrude 140 (about 300 lbs) on the back. I am using a Panther Marine Tech Model 40 tilt/trim bracket (27 lbs)(http://www.marinetechproducts.com/pages/TrimTiltModel40) to mount a 9.9 kicker (about 100 lbs) on.
With the kicker setup total approx weight on the transom is 425 lbs. Is this too much?
I also have battery and gas in the stern.
QUESTIONS:
1. Should I move the battery and gas to the bow?
2. If yes, is it okay to run the gas line all the way from the bow of the boat to the motor? If so what is the best routing path (down gunwale or under the floor)?
Thanks
QUESTIONS:
Thanks
