Weight of 1982 longshaft 4.5
mikehoyt
Johnson Seahorse J5RHLCN 4.5
Looking for the specs for this motor to ompare against other motors. Believe is somewhere around 52 lbs but can find nowhere. is there a list of specs by model on line somewhere?
Also - what is the RH in the model number? R is rope but the H mystifies me.
Mike
oldcatamount
Re: Weight of 1982 longshaft 4.5
"H" means "less integral tank/Hydraulic steering"
And all of that means, you have a separate fuel tank and no power steering!
Just guessing on the weight here but, you're pretty close at 52lbs I would think. (nice motor by the way)
Vic.S
"H" means it does not have an integral fuel tank.
("L" means longshaft)
It has reverse gear?
If so
the weight will be the same, I think, as later 4 hp deluxe models or thereabouts
That means 23.8 kg so yes around 52 lbs
