richierich1106
- Jul 20, 2008
- 9
i just took apart my outdrive and replaced all the gears and shims and bearings. im sure everything is in its correct place and it runs great except for a little weird humming. it sounds like it could be the bearings? could it be the shims i put just as many shims as i took out and made sure they were the same thickness. im going to take it apart again now but what should i do i think im going to try and add more shims so there will be more play is this a good idea?
