philtheskipper
- Jul 5, 2001
- 224
Just found out that my boat has two batteries hooked up with a switch. The switch can run both, or each one individually. What puzzles me is one is a typical (cranking) battery and the other is a deep cycle. I'm a bit confused cuz I was told both should be the same type. Is this an ok set-up? If it is, when should each battery be used/on? Should I have both on while the engine is running so they charge? When the engine is not in use should I run electronics off the deep cycle only or can I leave both on at all times?
