Re: Weird problem going to WOT
Ok, so i shifted manually and i have fwd neutral and reverse. but i could only do this if I disconnected the shift lever and pull up on the shift rod to go fwd and push down to go in reverse. So would this mean the adjustment is out? If so how do i adjust it so i works properly?
Down with the gearcase and adjust the vertical shift rod so the shift lever on the engine is verical.
The OEM manual has the measurement, but you might be able to figure out how much to adjust it.
Before pulling down the gear case, remove the screw going to the shift rod. Be sure the gear case is in neutral. put the shift lever that you attach the cable to vertical, then 'measure the height difference between the hole in the shift rod and the hole in the connector where the screw goes in. This will be about what you have to adjust by screwing the rod up or down.
