I know this is off topic for this forum, but thought I'd ask anyway. I have a 9.9 hp Johnson, which starts great, idles great, trolls great, but seems to be missing a horse or two on the top end. It used to run perfect, but now when I have it full throttle, it seems to not produce full power at first. I'll be at full throttle for 10 or 15 minutes, and then all of a sudden, another horse or two, and a few rpm's more kick in. It never used to do this, but the last two years it's been doing it. I've changed fuel filter, and made sure to have good gas. It has new plugs, and generally is in good shape. I don't think it's the high speed jet in the carb acting up, cuase if there was a blockage I figure once it went out, the problem would be cured, but this seems to happen the same way each time I run the motor. This happens after I've been trolling for a while as well, so it's not like the motor isn't warmed up. Anyone have any suggestions about all this, before I have to resort to paying money at a repair shop? <br /><br />Also, another question, I understand the only difference between the 9.9 hp and the 15 hp models is the carburetor. Is it just a straight across swap to put a 15 hp carb on the 9.9 motor? I think my motor is a 1981 model, if that adds more info. <br />Thanks for all the help.
