Welch plug serial no
marcysibyll
Is there a website that will give the year and HP rating if all I have is the engine welch plug serial no?<br />thanks
Paul Moir
Re: Welch plug serial no
We can sometimes look it up by referencing old Iboats posts. What S/N do you have?<br /><br />EDIT: This does not tell us the HP, but often that can be worked out easily enough.
marcysibyll
Paul, the ser. no. is j2968258. The mpower head is dark green, if that helps to narrow the search.<br /><br />thanks
Paul Moir
I searched this forum for J29 and turned up the following entrys:<br />J2985246 1968<br />J2974236 1968<br />j2968258 Yours<br />J2945926 1968<br />J2934597 1968<br />J2913741 1968<br /><br />And the colour green would match 1968 as well (for Johnson). So there's really no question about what year it is.<br /><br />As for HP, presuming this is an inline-2cylinder engine, here are the possibilities:<br />40hp: Roundish base (gasket surface), much larger than your 18hp. There is a thermostat tower on one side of the head.<br />33hp: Squarish base, much larger than your 18hp. There is no thermostat tower on the head, although the head is made of several peices.<br />20hp: Looks a *lot* like your 18hp.<br />9.5hp: Looks *very* strange. Carb comes off the back.<br />6hp: Looks "normal" but much smaller than your 18hp. There's a thermostat in the top of the head under a plate held in with three screws.<br />5hp: I think this powerhead is indestiguishable from the 6hp.<br />3hp: Very small, no thermostat (or thermostat cover) in the head.<br /><br />Hope that helps!<br /><br />(there is also a rare 15hp engine, but I think they were all painted grey)
marcysibyll
Thank you very much, Paul. I beleive that it's a 20 hp. <br /><br />This is the power head on my patchwork 18 fast twin. <br /><br />Now to get the throttle to work eqasily.<br /><br />\Thanks again.
