Hi guys and gals.
I am hoping to maybe get some ideas on what I should do. This may get a little long winded and I apologize.
I recently purchased a 1985 bayliner with the 260 Volvo and 270 outdrive. Bought it without a test drive due to space limitations all I could do is rev it at a dock. Engine sounds good and revs up fine but when underway at about 1000rpm if I try and throttle up to get on plane at about half throttle it bogs then sits at 2000rpm at full throttle i can slowly accelerate and it wont bog but still cuts out at 2000 rpm Since then I have talked to the guy who sold it to me and learned the following.
-PO changed the 270 outdrive to another 270 because a line ripped his prop seal on the original. I know there are 3 different 270 outdrives with different ratios and he doesn't know which is on there. Is there any way to identify gear ratio without removing the drive?
The prop is defiantly to small for the boat the manual says it should be a 15x19 and there is no way it is. So first I am going to get the right prop on there and see what happens.
Not sure if the small prop would cause the motor to cut out at 2000rpm I figure it would spin up and rev way high.
I have heard the auto choke could have been stuck closed causing the bog but I don't know.
I know I am stupid for buying the boat without testing properly so let's get that out of the way lol
Any help would be great
Thanks
Thanks
