Well I fixed my power tilt but I stripped the threads....
ruggles
on one side of the pivot bolt the connects the aft of the trim ram to the leg (pre alpha) wtf do I do now? Should I try to re- die it or can I find one of these new or used fairly easily. I was rushing and well into the cups and the ram wasn't perfectly lined up but I tried to squeeze it together and it basically pushed the bolt on sideways. :mad:
Re: Well I fixed my power tilt but I stripped the threads....
Ayuh,... Are you talking about the aft trim cylinder attachment Pin,..?? a 3/8" nut on each end,..?? fine threads,..??
When not greased they pull the threads...
I believe iboats sells 'em....
ruggles
You got it Bondo. That's the piece. It's from an old 76 pre alpha leg.
Thanks for the info.
