Wellcraft 290 Coastal plumbing question and close to tournament day....
mattkenton
We have been having problems with our livewell and have a tournament coming up. The problem is that the pump will turn on, start pumping, and nothing reaches the baitwell. There is a raw water outlet right next to the baitwell that is getting water. So i know the pump is working. Oh and this pump is not the main raw water pump for the A/C, it runs off its own seperate pump. Does anyone know if there is a valve that switches between this raw water outlet and the bait well? Or is it more than likely a clog at the T.
My common sense tells me that you could not have water going to both the raw water hose line AND the livewell without loosing water pressure. So i would think that there is a valve. So frustrated. Any help would be so greatly appreciated. Thank you.
I can provide photos if needed.
