Hey guys, I have a 2007 glastron 18ft F&S with 3.0 Volvo-Penta and SX outdrive. 3 batteries in back also. WOT rpm is 4200-4600. It came stock with a 3 blade alum 14.25 X 21 which was great at wot and ran 39mph (gps) at 4600 rpm but sucked off the line or when I had any more that two people on board. Didn't really have any handling issues as boat is very stable running in rough water at wot. My average day is with 3 ppl on board and pulling skier maybe a third of the time and cooler and snacks.
Switched to a 14.5 X 19 which gave me great hole shot and mid range power, but ran 34 mph and 5,000 rpm at wot. Seemed to handle the same, but slower.
So, I wanted one prop that would give me more grunt off the line and maybe only loose a couple of mph and not over rev like the 19 pitch was doing.
After lurking here and elsewhere and reading most everything I could I ordered a Michigan Wheel Apollo 4 blade stainless 14.25 X 20. Installed and ran it yesterday with 3 ppl on board and approx 18 gal of gas. Water was rough (1-2 ft) and choppy due to holiday traffic and wind, but found some protected calmer areas to test.
It sucked and here's why:
1. hole shot slightly better than 21 pitch, but not as good as 19pitch 3 blade. Not what I wanted, but I could live with that if not for the other issues.
2. ran 33mph at 4150 rpms......so I'm not near my 4600 goal and speed sucks
3. Boat cornered nice and tight and seemed to hold rpms and speed better in tight turns in smooth water, but was very unstable at top end in the rough water and started bouncing severely from side to side (chine walking?) and we dang near crashed. I've driven it many times faster than this in rougher water than this and never had that happen.
4. And strangely, the boat tended to porpoise at any speed and no matter the trim. In fact, after a few minutes I just gave up and left the trim in the full down.
So, first off, I've got a brand new slightly wet Apollo 4 blade stainless for sale.
I'm very concerned about buying another 4 blade. Was thinking about getting a stainless 4 blade 19 pitch, but I'm thinking that "stern lift" is not healthy for my boat. Is my hull one that may not benefit from a 4 blade?
Should I just get a good stainless 3 blade 19 pitch and be careful about the rpms?
No "prop shops" anywhere close to me. But being as I have 3 props in my garage right now, I may open one up.
Your thoughts would be appreciated.
