West Marine On & Off
FreeBeeTony
If anyone is interested in a good product to get the brown stain off above the water line, try On & Off at West Marine.
This is the first time I used it and it worked great. Just sprayed it on and then used the power washer............
stevieray
Re: West Marine On & Off
FBT - it is one of my favorites, too. I have recommended it in several other posts here as well.
Reel Poor
Their Rust Stain Remover is great for the same purpose. It has a higher volume of the active ingrediant found in On-Off. Just spray it on and watch the stains disappear. No scrubbing necessary. Just wash and wax when done.
BTW, after using the On-Off you should reapply wax back on the hull.
tashasdaddy
sounds like something i need for the shower.
FreeBeeTony
Going to apply the wax in the spring............
Did turn the trailer a little black though..............even after a thourough rinse.
stevieray
FBT - it says right on the bottle to cover up the trailer :=
crazy charlie
I will save you ALL a bunch of money.Instead of the On-Off,go to Walmart and buy the $1.29 toilet bowl cleaner.I think the name may be Sno-Bowl.It is also an acid just as On-Off is .You may have to leave it on for a a minute or two longer than the On-Off but the results are the same.I have used it for years with great results.Charlie
