wet epoxy?
montara24d
I have a 16' aluminum Lund. I believe that the floation under the floor has absorbed salt water, and is causing corrosion. I realize that the floor must come up & all water soaked material removed & replaced. As a temp. fix does anyone know of an epoxy, or 5200 type material that can be applied to the outside of the hull, as the pinholes continue to weep. John
ondarvr
Not a good fix, if you have pin holes all over the place the aluminum has deteriorated to the point where it probably isn't safe.
gm280
Pictures first. We can't guess what needs to be done without seeing what you're seeing.
Ned L
Yep,... Need more details. I don't know that I'd automatically say it isn't safe. Depending on how you intend to use the boat and what you expect out of it there may be things you can do.
If you are expecting an almost 'invisible' repair, and want to use the boat in extended open water then your options may be more limited. If it is pretty much a knock around boat for local exploring and gunk holing then there are probably lots of things you can do. There are lots of products (latex caulking, construction adhesives, etc) that will keep the water out.
While growing up we had an old beater 12' aluminum john boat ( actually bought it new, but after 20 yrs of hard salt water use it was pretty tired.). In the spring we would go over the bottom wire brushing the loose rivets, cracks and anything else that looked like it might lead, then we would apply a dab of whatever we had laying around the house. It would be good to go for the season. By the end of the season things would have loosened up again to the point that after a couple of hours in the water there would also be a good couple of inches in it. It was never anything we would have called 'unsafe'.
Had lots of fun with it, at times we would take it out and intentionally roll it over, climb on the bottom, swim under it to the air pockets in it and generally use it as a water toy. When done we would role it back over, slosh a good bit of the water out, climb in and row back to shore. More than a couple of times a passing boat asked if we needed help--- just having fun.
Watermann
I would pull the decking out and remove all the foam as there is no handy man in a can quick fix for what you're describing. If the pitting is limited to a few areas then it can most likely be dealt with from the inside where it started but not from the outside. To give further advice is difficult since we don't yet know the extent of the corrosion.
Patfromny
Hey Ned L, what is gunk holing? Sorry to hijack but it made me laugh pretty good and I don't even know what it is.
Ned L
I suppose it relates a bit more to actual cruising, but it means just sort of poking your way along and stopping along the way in little back waters and out of the way places as you go.
I suppose it does sound pretty funny if you're not used to the term. :)
